[progress Communities] [progress Openedge Abl] Forum Post: Re: Need Urgent Help For Output...
Mark Davies
It looks like it is being escaped - that is usually what the \ is for. How are you writing your output? Is lcFieldValue a LONGCHAR? Any reason why you didn't opt for using EXPORT DELIMITER "," ttTableRecords. ? That will help if you need to go directly to file and will dump quotes around string values.
