Sivarami Reddy Marella
Hi Anand, Thanks for your help. Now I am running the same programs, which are run for local queue and I am using same queue name for remote Queue also. Now I am getting the below error message. Please find the sonicmq log. S-0001>(Jul 7, 2017 15:12:55:218) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: Startup Parameters: jmsServerName: Point-To-Point brokerURL: TestQueueManager user: password: clientID: null pingInterval: transactedPublish: false transactedReceive: false singleMessageAck: false symbiontAdapter: false jmsDomain: true S-0001>(Jul 7, 2017 15:12:55:218) S-0001: receive message queue size set to 10 S-0001>(Jul 7, 2017 15:12:55:219) S-0001: browse message queue size set to 500 S-0001>(Jul 7, 2017 15:12:55:219) : In SessionContainer() S-0001>(Jul 7, 2017 15:12:55:219) : Looking up ConnectionFactory in JNDI Object Store S-0001>(Jul 7, 2017 15:12:55:219) : Connection Factory object not found in JNDI Object Store. Creating using jmsProvider.properties file S-0001>(Jul 7, 2017 15:12:55:219) : Creating JMS connection factory with Broker URL as [ TestQueueManager ] S-0001>(Jul 7, 2017 15:12:55:220) : Setting Queue Manager TestQueueManager on Connection Factory Class com.ibm.mq.jms.MQConnectionFactory S-0001>(Jul 7, 2017 15:12:55:220) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: Using connection values: 26,null,true,,true,false,-1,-1,false,0,false,false,,10000,0,30,false,60,0,20,0,,null,null,CTSC00520904801,localhost S-0001>(Jul 7, 2017 15:12:55:228) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: A JMS session has been created. (9291) Thread-53>(Jul 7, 2017 15:12:55:236) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: getNextMessage(): Client requests next message. Thread-51>(Jul 7, 2017 15:12:55:237) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: receive(): Request to receive from: RMQ. Thread-51>(Jul 7, 2017 15:12:55:239) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97 com.ibm.msg.client.jms.DetailedJMSException: JMSWMQ1017: non-local MQ queue 'RMQ' not valid for receiving or browsing. The MQ queue is not able to be opened, as it is not local to the connected Queue Manager. Connect to the Queue Manager for which this MQ Queue resides locally. at com.ibm.msg.client.wmq.common.internal.Reason.reasonToException(Reason.java:595) at com.ibm.msg.client.wmq.common.internal.Reason.createException(Reason.java:215) at com.ibm.msg.client.wmq.internal.WMQMessageConsumer.checkJmqiCallSuccess(WMQMessageConsumer.java:213) at com.ibm.msg.client.wmq.internal.WMQMessageConsumer.checkJmqiCallSuccess(WMQMessageConsumer.java:261) at com.ibm.msg.client.wmq.internal.WMQMessageConsumer.checkJmqiCallSuccess(WMQMessageConsumer.java:153) at com.ibm.msg.client.wmq.internal.WMQConsumerShadow.initialize(WMQConsumerShadow.java:1179) at com.ibm.msg.client.wmq.internal.WMQSyncConsumerShadow.initialize(WMQSyncConsumerShadow.java:134) at com.ibm.msg.client.wmq.internal.WMQMessageConsumer. (WMQMessageConsumer.java:471) at com.ibm.msg.client.wmq.internal.WMQSession.createConsumer(WMQSession.java:877) at com.ibm.msg.client.jms.internal.JmsSessionImpl.createConsumer(JmsSessionImpl.java:993) at com.ibm.msg.client.jms.internal.JmsSessionImpl.createConsumer(JmsSessionImpl.java:1052) at com.ibm.mq.jms.MQSession.createConsumer(MQSession.java:439) at com.progress.messaging.jms.ListenerCollection.createConsumer(ListenerCollection.java:317) at com.progress.messaging.jms.ListenerCollection.createListener(ListenerCollection.java:147) at com.progress.messaging.jms.ListenerCollection.createDestinationListener(ListenerCollection.java:127) at com.progress.messaging.jms.SessionContainer.receive(SessionContainer.java:795) at com.progress.messaging.jms.SessionContainer.receive2(SessionContainer.java:825) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.progress.javafrom4gl.implementation.MethodHolder.invoke(MethodHolder.java:168) at com.progress.javafrom4gl.implementation.RequestExecuter$Request.executeRequest(RequestExecuter.java:264) at com.progress.javafrom4gl.implementation.RequestExecuter.executeRequest(RequestExecuter.java:70) at com.progress.javafrom4gl.implementation.RequestThread.go(RequestThread.java:63) at com.progress.javafrom4gl.implementation.RequestThread.run(RequestThread.java:38) Caused by: com.ibm.mq.MQException: JMSCMQ0001: WebSphere MQ call failed with compcode '2' ('MQCC_FAILED') reason '2045' ('MQRC_OPTION_NOT_VALID_FOR_TYPE'). at com.ibm.msg.client.wmq.common.internal.Reason.createException(Reason.java:203) ... 24 more Thread-51>(Jul 7, 2017 15:12:57:437) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: start(): Starting message reception. Thread-51>(Jul 7, 2017 15:12:57:438) 10.242.244.47::sonicMQ1::3620::f9cd250ea34bfa0f:1a15cb38:15d1c38d8b5:-7f97: start(): Message reception started. Thanks, Sivarami
