[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: ABL interop between agent code (in ABL) and the tomcat HTTP session
Michael Jacobs
For APSV connections the HTTP Session existence is controlled inside the transport itself. All other transports are controlled via Spring and the Tomcat session timeout. The APSV transport should obviously be terminating those HTTP sessions when the client disconnects. The fallback is to allow TC to harvest the expired sessions later. The better case is to cleanup on client disconnect and ensure the clients always disconnect. It is possible to disable the use of HTTP Sessions in the conf/openedge.properties configuration (useHTTPSessions) and test your application. Note: this setting does not affect any transport other then APSV. If changing that property does not affect, or resolve, this bad behavior for you we need to know.
