anzki4
I have some weird port issues. I have created PAS server with the following command: "tcman create -p 9110 -P 9111 -s 9112 -j 9113 -N pas-internal-dev {path_to_pas_server_here}" When I try to start the server, I get the following error from agent log (other logs have no errors): [18/06/19@15:45:25.149+0300] P-006656 T-011064 1 AS-Aux-0 MSAS Agent Starting Up -- Progress OpenEdge Release 11.7 build 1497. [18/06/19@15:45:25.149+0300] P-006656 T-011064 1 AS-Aux-0 -- Logging level set to = 2 [18/06/19@15:45:25.149+0300] P-006656 T-011064 1 AS-Aux-0 -- Log entry types activated: ASPlumbing,DB.Connects [18/06/19@15:45:25.150+0300] P-006656 T-011064 2 AS-Aux-0 AS Starting MSAS Session for pas-internal-dev. [18/06/19@15:45:25.155+0300] P-006656 T-011064 2 AS-Aux-0 AS MSAS Session Startup. (5473) [18/06/19@15:45:25.163+0300] P-006656 T-011064 1 AS-Listener -- Log entry types activated: ASPlumbing,DB.Connects [18/06/19@15:45:25.163+0300] P-006656 T-011064 2 AS-Listener AS Starting MSAS Session for pas-internal-dev. [18/06/19@15:45:25.164+0300] P-006656 T-011064 2 AS-Listener AS MSAS Session Startup. (5473) [18/06/19@15:45:25.176+0300] P-006656 T-011064 1 AS-Listener -- Service transport TCP is busy. (5485) [18/06/19@15:45:25.176+0300] P-006656 T-011064 1 AS-Listener -- TCP is busy, no free ports available between min/max range (-3534 - -3334) (15765) [18/06/19@15:45:25.176+0300] P-006656 T-011064 2 AS-Listener AS MSAS Session initialisation failure. (5475) [18/06/19@15:45:25.176+0300] P-006656 T-011064 1 AS-Listener MSAS Unable to initialize service for session! [18/06/19@15:45:25.176+0300] P-006656 T-011064 1 AS-Listener MSAS Unable to initialize listener thread context! Neither of those ports (3334, 3534) is not mentioned in any PAS server configuration files or any progress configuration files. From the PAS server configuration (file: {path_to_pas_server}/conf/openedge.properties) the default AppServer.Agent port range is from 62001 to 62202. If I change those ports to anything other than the default, I get the following error instead (where {PORT_NUMBER_HERE} is the first free port from beginning of the port range): [18/06/27@11:31:10.637+0300] P-012964 T-007828 1 AS-Aux-0 MSAS Agent Starting Up -- Progress OpenEdge Release 11.7 build 1497. [18/06/27@11:31:10.637+0300] P-012964 T-007828 1 AS-Aux-0 -- Logging level set to = 2 [18/06/27@11:31:10.637+0300] P-012964 T-007828 1 AS-Aux-0 -- Log entry types activated: ASPlumbing,DB.Connects [18/06/27@11:31:10.637+0300] P-012964 T-007828 2 AS-Aux-0 AS Starting MSAS Session for pas-internal-dev. [18/06/27@11:31:10.642+0300] P-012964 T-007828 2 AS-Aux-0 AS MSAS Session Startup. (5473) [18/06/27@11:31:10.652+0300] P-012964 T-007828 1 AS-Listener -- Log entry types activated: ASPlumbing,DB.Connects [18/06/27@11:31:10.652+0300] P-012964 T-007828 2 AS-Listener AS Starting MSAS Session for pas-internal-dev. [18/06/27@11:31:10.652+0300] P-012964 T-007828 2 AS-Listener AS MSAS Session Startup. (5473) [18/06/27@11:31:10.669+0300] P-012964 T-007828 1 AS-Listener MSAS Spawning New Worker Thread. Number: 4 [18/06/27@11:31:10.674+0300] P-012964 T-013744 1 AS-ResourceMgr -- Log entry types activated: ASPlumbing,DB.Connects [18/06/27@11:31:10.674+0300] P-012964 T-013744 2 AS-ResourceMgr AS Starting MSAS Session for pas-internal-dev. [18/06/27@11:31:10.674+0300] P-012964 T-013744 2 AS-ResourceMgr AS MSAS Session Startup. (5473) [18/06/27@11:31:52.672+0300] P-012964 T-013744 1 AS-ResourceMgr -- Connection failure for host WMLI118037 port {PORT_NUMBER_HERE} transport TCP. (9407) [18/06/27@11:31:52.672+0300] P-012964 T-013744 1 AS-ResourceMgr MSAS Resource Manager could not establish connection to listener socket. [18/06/27@11:32:10.669+0300] P-012964 T-007828 1 AS-Listener MSAS Agent Shutting Down. Status: -1000 [18/06/27@11:32:10.669+0300] P-012964 T-011012 1 AS-Aux-0 MSAS Worker Thread exiting. Number: 4, Status: -16 [18/06/27@11:32:10.669+0300] P-012964 T-007828 1 AS-Listener MSAS Spawning New Worker Thread. Number: 5 [18/06/27@11:32:10.669+0300] P-012964 T-012148 1 AS-Aux-0 MSAS Worker Thread exiting. Number: 5, Status: 0 [18/06/27@11:32:10.670+0300] P-012964 T-007828 1 AS-Listener MSAS Agent Shutdown Complete.
