[Progress Communities] [Progress OpenEdge ABL] Forum Post: PASOE - analyse and recover from high CPU problem ... runaway program
  • Thread starter mroberts@rev.com.au
  • Start date
mroberts@rev.com.au
Morning All, PASOE 11.7.2 on Linux 64 bit environment I have 3 PASOE instances that have migrated recently to 11.7.2 from 10.2B08, and are using PAS instead of classic appserver. These are the first PASOE instances we are using in production. Each one is now running high CPU, and I have applied my classic appserver methodology to hunt the offending code. I have found on each of the PASOE instances, and agent session that has been running for over a day, with a status of Executing, and a line number of 0 on the CallStack ... sample below "ABLStacks": [ { "AgentSessionId": 4, "Callstack": [ { "Line": 0, "Routine": "sys/da_getui01.p", "Source": "/tunz/dealer/bl/sys/da_getui01.r" } ], "Status": "Executing" } ] For each PASOE instance, the program name differs, but the line number remains consistent with 0 So, something has gone bad, and the program is spinning, using LOTS of CPU. The silver lining on this is that none of the end users have noticed, the PAS is still serving requests with no apparent loss of service to the users ... I like this! It's an improvement from 10.2B But now, I am trying the kill off the day old threads, without resorting to an outage for the users. In the "classic" days, I would have done a kill -SIGUSR1 on the PID, got the stack trace for follow up, disconnected the PID from the databases, and then used ever increasing severity of kill commands until the process was gone. So I have tried the following on one of the PAS servers, using oemanager REST APIs 1) trim IDLE Sessions ... nothing happened (DELETE http://server/oemamanger/applications/appid/agentid/sessions ) 2) Terminate the session gracefully (DELETE http://server/oemamanger/applications/appid/sessions ?sessionID=sessid&terminatept=0) ... did not work 3) Terminate session Forcefully (DELETE http://server/oemamanger/applications/appid/sessions ?sessionID=sessid&terminatept=1) ... session went away, but thread running program remained 2) Trim Agent - (DELETE http://server/oemamanger/applications/appid/agents/agentid ) ... the agent has been stuck in STOPPING for 12 hours, and the CPU is still impressive Now I'm stuck, with high CPU, and agent stuck in stopping, and I'm afraid if I try anything else I might do more damage than good. I don't want to wield the kill wand around and take the database out as well. So, I'm going to arrange an outage for these 3 customers to stop everything cleanly and start stuff back up, but was wanting advice on the correct way to kill thing off in this instance without resorting to an outage. Thing I have noticed are 1) There does not seem to be an API to kill or stop a thread if required. The only stop is for a session, and in this instance, stopping it did not stop the underlying thread 2) There is no API to start a new agent. Before stopping an existing agent, I would really like to start a second one to have it handling calls before I stop the first one. Once you stop an agent, there is a time gap in starting a replacement that could be filled, if I could preemptively start the replacement. In my case above, the PAS instance started a secondary agent itself at some stage (no input from me), that meant I could stop the first one and be sure that the second one was handling requests 3) Documentation points towards jConsole and JMX as an alternative to oemanager, but the stuff I have read does not show any detail of what it offers, and my testing on a test server, shows it exposes overall memory and CPU usage, but does not do it down to thread level. Also, the mBeans is exposes seem to offer the same controls that are available to oemanager. I'm willing to learn more about this option, but documentation seems to be sparse. So, I'm wondering if anyone out there has hit this hurdle yet, and what they might have done to clear away the offending threads without resorting to an outage for the users. It's thing thing about classic appserver I liked the best, a lot of things could go bad behind the scenes, and as long as the broker was still running, combinations of trim agents, start agents and os level killing could resolve them with end users being none the wiser. I need to do this is PASOE now, and have run out of ideas! Thanks Mark
