Migrating Progress from 16-bit to 32-bit
Chris Kelleher
Administrator
Staff member
<STRONG>Migrating Progress Application from 16 to 32-bit</STRONG> Word 97 Document or HTML version</A>.This guide is designed to help you migrate your applications from a 16-bit to a 32-bit environment. It identifies the technical issues you might encounter and the steps necessary to make the migration smooth. To provide support for the 32-bit environment, several Progress features have been changed and will have an immediate impact on your applications. This guide will help you develop a plan for the migration.
