F
Fuelfire
Garry, thanks a lot! Now I will rewrite initialization of MEMPTR ObjDesc and report the results later. If I understand correctly, I consistently pass the value structure field without field names. But how to build the correct sequence? How I can be pretty sure that firstly I must pass StructId and then Version, but not vice versa? Apparently, I have to focus on the sequence of fields, which is described in the section "Initial values of fields in MQOD"? In this table, the first field is StructId, then Version, Object Type, ObjectName, ObjectQMgrName and so on. Is it right? Thanks.
