Changing Excel Fonts & Colors
cesaroll
Hi everyone,
What I want to do is to change color and fonts in some cells of an excel spreadsheet generated with progress, does anyone has an example or someting?
Thanks!!
francis_aro
Hi,
Hope that the following codes will help you to solve the problem.
Note: the following commands for changing format, font & colors.
chWorkSheet:Range("B2:C10"):Select().
chExcelApplication:Selection:FONT:Name = "Impact".
chExcelApplication:Selection:FONT:ColorIndex = 45.
chExcelApplication:Selection:Style = "Currency".
DEFINE VARIABLE chExcelApplication AS COM-HANDLE.
DEFINE VARIABLE chWorkbook AS COM-HANDLE.
DEFINE VARIABLE chWorksheet AS COM-HANDLE.
DEFINE VARIABLE chChart AS COM-HANDLE.
DEFINE VARIABLE chWorksheetRange AS COM-HANDLE.
DEFINE VARIABLE iCount AS INTEGER.
DEFINE VARIABLE iIndex AS INTEGER.
DEFINE VARIABLE iTotalNumberOfOrders AS INTEGER.
DEFINE VARIABLE iMonth AS INTEGER.
DEFINE VARIABLE dAnnualQuota AS DECIMAL.
DEFINE VARIABLE dTotalSalesAmount AS DECIMAL.
DEFINE VARIABLE iColumn AS INTEGER INITIAL 1.
DEFINE VARIABLE cColumn AS CHARACTER.
DEFINE VARIABLE cRange AS CHARACTER.
/* create a new Excel Application object */
CREATE "Excel.Application" chExcelApplication.
/* launch Excel so it is visible to the user */
chExcelApplication:Visible = TRUE.
/* create a new Workbook */
chWorkbook = chExcelApplication:Workbooks:Add().
/* get the active Worksheet */
chWorkSheet = chExcelApplication:Sheets:Item(1).
/* set the column names for the Worksheet */
chWorkSheet:Columns("A"):ColumnWidth = 18.
chWorkSheet:Columns("B"):ColumnWidth = 12.
chWorkSheet:Columns("C"):ColumnWidth = 12.
chWorkSheet:Range("A1:C1"):Font:Bold = TRUE.
chWorkSheet:Range("A1"):Value = "SalesRep".
chWorkSheet:Range("B1"):Value = "Total Sales".
chWorkSheet:Range("C1"):Value = "Annual Quota".
/* Iterate through the salesrep table and populate
the Worksheet appropriately */
FOR EACH salesrep:
dAnnualQuota = 0.
iTotalNumberOfOrders = 0.
dTotalSalesAmount = 0.
iColumn = iColumn + 1.
FOR EACH order OF salesrep:
iTotalNumberOfOrders = iTotalNumberOfOrders + 1.
FIND invoice WHERE invoice.order-num = Order.order-num NO-ERROR.
IF AVAILABLE invoice THEN
dTotalSalesAmount = dTotalSalesAmount + invoice.amount.
END.
DO iMonth = 1 TO 12:
dAnnualQuota = dAnnualQuota + salesrep.month-quota[iMonth].
END.
cColumn = STRING(iColumn).
cRange = "A" + cColumn.
chWorkSheet:Range(cRange):Value = salesrep.rep-name.
cRange = "B" + cColumn.
chWorkSheet:Range(cRange):Value = dTotalSalesAmount.
cRange = "C" + cColumn.
chWorkSheet:Range(cRange):Value = dAnnualQuota.
END.
/* create embedded chart using the data in the Worksheet */
chWorksheetRange = chWorksheet:Range("A1:C10").
chWorksheet:ChartObjects:Add(10,150,425,300):Activate.
chExcelApplication:ActiveChart:ChartWizard(chWorksheetRange, 3, 1, 2, 1, 1, TRUE,
"1996 Sales Figures", "Sales Person", "Annual Sales").
/* create chart using the data in the Worksheet */
chChart=chExcelApplication:Charts:Add().
chChart:Name = "Test Chart".
chChart:Type = 11.
/* release com-handles */
RELEASE OBJECT chExcelApplication.
RELEASE OBJECT chWorkbook.
RELEASE OBJECT chWorksheet.
RELEASE OBJECT chChart.
RELEASE OBJECT chWorksheetRange.
cesaroll said:
Hi everyone,
Thanks!!
cesaroll
Excellent, thank you very much, it works very good.
I just have a question, what I'm doing is creating a simple report, When I send it to a .txt file it works very fast, but if I send it to Excel it works very very slow, I don't know why?, maybe Progress and COM don't work very fine together.
This is my code:
DEFINE VARIABLE chExcel AS COM-HANDLE.
DEFINE VARIABLE cRen AS CHARACTER NO-UNDO.
DEFINE VARIABLE iRen AS INTEGER NO-UNDO.
DEFINE VARIABLE i AS INTEGER NO-UNDO.
DO ON ERROR UNDO, RETRY:
IF RETRY THEN
DO:
IF VALID-HANDLE(chExcel) THEN
RELEASE OBJECT chExcel NO-ERROR.
IF VALID-HANDLE(chWorkbook) then
RELEASE OBJECT chWorkbook NO-ERROR.
IF VALID-HANDLE(chWorksheet) then
RELEASE OBJECT chWorksheet NO-ERROR.
IF VALID-HANDLE(chWorksheetRange) then
RELEASE OBJECT chWorksheetRange NO-ERROR.
ASSIGN chExcel = ?
chWorkbook = ?
chWorksheet = ?
chWorksheetRange = ?.
RETURN.
END.
END.
/* CREA Excel Application object */
CREATE "Excel.Application" chExcel.
/* CREA EL Workbook */
chWorkbook = chExcel:Workbooks:Add().
FOR EACH ttPerfiles
NO-LOCK:
/* Create Worksheet */
ASSIGN chWorkSheet = chExcel:Sheets:Add().
chWorkSheet:NAME = "P-" + STRING(ttPerfiles.iCvePerfil).
chWorkSheet:Range("A3:G8"):FONT:Name = "Comic Sans MS".
/* Configure Columns*/
chWorkSheet:Columns("A"):ColumnWidth = 46.57.
chWorkSheet:Columns("B"):ColumnWidth = 8.43.
chWorkSheet:Columns("C"):ColumnWidth = 19.57.
chWorkSheet:Columns("D"):ColumnWidth = 8.14.
chWorkSheet:Columns("E"):ColumnWidth = 8.14.
chWorkSheet:Columns("F"):ColumnWidth = 8.14.
chWorkSheet:Columns("G"):ColumnWidth = 13.43.
chWorkSheet:Columns("B"):HorizontalAlignment = 3.
chWorkSheet:Columns("C"):HorizontalAlignment = 3.
chWorkSheet:Columns("D"):HorizontalAlignment = 3.
chWorkSheet:Columns("E"):HorizontalAlignment = 3.
chWorkSheet:Columns("F"):HorizontalAlignment = 3.
chWorkSheet:Columns("G"):HorizontalAlignment = 3.
chWorkSheet:Range("B2"):Value = "User Profile".
chWorkSheet:Range("B2"):FONT:Bold = TRUE.
chWorkSheet:Range("B2"):FONT:SIZE = 18.
chWorkSheet:Range("A4"):Value = "Profile Code:".
chWorkSheet:Range("B4"):Value = STRING(ttPerfiles.iCvePerfil).
chWorkSheet:Range("B4"):Interior:ColorIndex = 35.
chWorkSheet:Range("B4"):FONT:Bold = TRUE.
DO i = 7 TO 10:
chWorkSheet:Range("B4"):Borders(i):LineStyle = 1.
END.
chWorkSheet:Range("A5"):Value = "Profile Description:".
chWorkSheet:Range("C5"):Value = STRING(ttPerfiles.cDescPerfil).
chWorkSheet:Range("B5:F5"):Interior:ColorIndex = 35.
chWorkSheet:Range("C5"):FONT:Bold = TRUE.
DO i = 7 TO 10:
chWorkSheet:Range("B5:F5"):Borders(i):LineStyle = 1.
END.
chWorkSheet:Range("A6"):Value = "Definition Date:".
chWorkSheet:Range("B6:C6"):Interior:ColorIndex = 35.
chWorkSheet:Range("B6:C6"):FONT:Bold = TRUE.
DO i = 7 TO 10:
chWorkSheet:Range("B6:C6"):Borders(i):LineStyle = 1.
END.
chWorkSheet:Range("A7"):Value = "Authorized By:".
chWorkSheet:Range("B7:F7"):Interior:ColorIndex = 35.
chWorkSheet:Range("B7:F7"):FONT:Bold = TRUE.
DO i = 7 TO 10:
chWorkSheet:Range("B7:F7"):Borders(i):LineStyle = 1.
END.
chWorkSheet:Range("A9"):Value = "Description".
chWorkSheet:Range("B9"):Value = "Shortcut".
chWorkSheet:Range("C9"):Value = "C".
chWorkSheet:Range("D9"):Value = "C / M".
chWorkSheet:Range("E9"):Value = "C / M / I".
chWorkSheet:Range("F9"):Value = "C / M / B".
chWorkSheet:Range("G9"):Value = "C / M / I / B".
chWorkSheet:Range("A9:G9"):FONT:Bold = TRUE.
chWorkSheet:Range("A9:G9"):FONT:SIZE = 8.
DO i = 7 TO 11:
chWorkSheet:Range("A9:G9"):Borders(i):LineStyle = 1.
END.
iRen = 10.
FOR EACH ttMenu
NO-LOCK:
cRen = STRING(iRen).
chWorkSheet:Range("A" + cRen + ":G" + cRen):FONT:Name = "Comic Sans MS".
DO i = 7 TO 11:
chWorkSheet:Range("A" + cRen + ":G" + cRen):Borders(i):LineStyle = 1.
END.
IF ttMenu.lHijos THEN
chWorkSheet:Range("A" + cRen):FONT:Bold = TRUE.
chWorkSheet:Range("A" + cRen):Value = ttMenu.cDescMenu.
IF ttMenu.iNivel > 0 THEN
chWorkSheet:Range("A" + cRen):InsertIndent(ttMenu.iNivel).
chWorkSheet:Range("B" + cRen):Value = ttMenu.iCveMenu.
chWorkSheet:Range("C" + cRen + ":G" + cRen):FONT:Bold = TRUE.
chWorkSheet:Range("C" + cRen + ":G" + cRen):Interior:ColorIndex = 35.
FIND FIRST ttPermisos
WHERE ttPermisos.iCveMenu = ttMenu.iCveMenu
AND ttPermisos.iCvePerfil = ttPerfiles.iCvePerfil
NO-LOCK NO-ERROR.
IF AVAILABLE ttPermisos THEN DO:
CASE ttPermisos.iCveAttrib:
WHEN 1 THEN
cRen = "C" + cRen.
WHEN 2 THEN
cRen = "D" + cRen.
WHEN 3 THEN
cRen = "E" + cRen.
WHEN 4 THEN
cRen = "F" + cRen.
WHEN 5 THEN
cRen = "G" + cRen.
OTHERWISE
cRen = ''.
END CASE.
IF cRen <> '' THEN
chWorkSheet:Range(cRen):Value = "x".
END.
iRen = iRen + 1.
END. /* FOR EACH ttMenu */
RELEASE OBJECT chWorkSheet.
ASSIGN chWorkSheet = ?.
END. /* FOR EACH ttPerfiles */
ASSIGN chExcel:Visible = TRUE.
/* RELEASE COM-HANDLES */
/*IF VALID-HANDLE(chWorksheet) THEN
RELEASE OBJECT chWorksheet NO-ERROR.*/
pejgan
It's true that exporting data to Excel/Word is extremely slow in comparison to sending directly to a textfile. From what I can see from just a quick look at your code it seems you are doing what you should. Sorry no good tips ... "been there tried that" .
