Comment using .NET to test if a process exists.
Cecil
This is a simple test using .NET to see if a process is already running. Before, I was using tasklist command and then parsing the output. This code could be adapted to include more information. However, I have not figured out how to cast a .NET array to an ABL extent yet.
USING System.Diagnostics.*.
FUNCTION isProcessExist RETURNS LOGICAL (INPUT processName AS CHARACTER):
    DEFINE VARIABLE strArr AS CLASS System.Collections.IList NO-UNDO.
    DEFINE VARIABLE sysProcesses AS CLASS "System.Diagnostics.PROCESS[]".
    sysProcesses = System.Diagnostics.Process:GetProcessesByName(INPUT processName).
    RETURN LOGICAL( sysProcesses:LENGTH ).
END FUNCTION.
MESSAGE isProcessExist("notepad").
Cecil
the function also displays information about the running process.
REF: Process.Responding Property (System.Diagnostics)
       DEFINE VARIABLE sysProcesses AS CLASS "System.Diagnostics.Process[]".
       DEFINE VARIABLE sysProcess   AS CLASS System.Diagnostics.Process.
       DEFINE VARIABLE i AS INTEGER     NO-UNDO.
    DO i = 0 TO sysProcesses:LENGTH - 1:
        sysProcess = CAST(sysProcesses:GetValue(i), System.Diagnostics.Process).
        MESSAGE sysProcess:ProcessName sysProcess:Id sysProcess:TotalProcessorTime sysProcess:Responding .
    END.
END FUNCTION.
RealHeavyDude
Well-Known Member
As far as I know you can't directly cast a .NET array to ABL extents. You need to capture the output as .NET System.Array, iterate over the array and cast each individual member to what you expect.
define variable currentDomain  as System.AppDomain            no-undo.
define variable assemblies     as System.Array                no-undo.
define variable assembly       as System.Reflection.Assembly  no-undo.
define variable assemblyNo     as integer     no-undo.
/* Grab the current domain */
assign currentDomain = System.AppDomain:CurrentDomain.
/* Get an array of currently loaded assemblies */
assign assemblies = currentDomain:GetAssemblies ( ).
/* Loop through the array of assemblies */
do assemblyNo = 1 to assemblies:Length:
    assign assembly = cast ( assemblies:GetValue ( assemblyNo - 1 ), System.Reflection.Assembly ).
    infoMessage ( substitute ( 'ASSEMBLY: &1.', assembly:FullName ) ).
end.
Something like the above for example.
