1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
ProTop 3.1 has escaped!
Discussion in 'Database Admin' started by TomBascom, May 8, 2013.
  1. TomBascom
    TomBascom Curmudgeon
    This new release features an all new user interface (two of them actually), new "server agent" components and the usual bug fixes and improvements that any new release has.
    Caveats:
    1) You must be running OpenEdge 10.2 or better (the old release remains available for people who are still using ancient, obsolete and unsupported versions of Progress).
    2) Terminal windows must be at least 132 columns by 48 lines -- 80 x 24 is no more.
    3) You should install the new release in a new directory. The install script makes no attempt to upgrade an older release and it will probably break something if you install in the same place.
    4) It's new. There are probably bugs.
    Download ProTop 3.0 at http://dbappraise.com/protop.html
    Feel free to corner me at PUG Challenge Americas, June 9-12, ask questions, complain about the documentation, lobby for new features or just shoot the breeze! If you haven't registered yet head on over to:
    http://pugchallenge.org/register.html
  2.
  3. Rob Fitzpatrick
    Rob Fitzpatrick ProgressTalk.com Sponsor
    Just started looking at it, and haven't started looking at the code yet, but so far I like what I see a lot. Great job Tom et al.
    I love the dashboard's organization of metrics by functional area: buffering and I/O, AI and BI subsystems, transaction stats, APW stats, and client/server stats. Also the configuration viewer is a nice way to see important metrics and startup parameter values at a glance.
    (I do sorely miss cumulative CRUD stats though. :'( Oh well; I still have my own code and ProTop xxi for that.)
  4. kctechllc
    kctechllc New Member
    I'm getting the following error trying to connect to a remote server through the web interface.
    Error reading XML file '.../cgi-bin/protop.cgi?type=pt3web&DB=vision&UID=cf232fb5-e497-a5b7-e211-5dd381cfa39e&GUID=cf232fb5-e497-a5b7-e211-83d35cbbf06b&DC=Dashboard'. (13035)
    READ-XML encountered an error while parsing the XML Document: FATAL ERROR: file
  5. kctechllc
    Got it fixed, error in my httpd.conf. Works great.
  6. TomBascom
    Glad to hear it!
  7. pinne65
    pinne65 Member
    Hi Tom,
    Thanks for a great tool!
    I have a question: When running the self service client through (ssh Putty / vt220,vt100,xterm) I move can't move between or resort the different result tables. The default startup screen with just "Table activity" and "User IO" results will just allow me to scroll the whole "Table Activity" up or down with the arrow keys. I was thinking PgUp/Dn or Tab would allow me to switch between result tables and some other key-combo would allow me to jump between and sort fields within a table. What happens now is that the arrow up/down keys scrolls the next to last added table up or down. I.e. the focus moves to table n-1 but there's no way of changing focus to another. I'm not sure if this is by design or if I have Putty configured incorrectly.
    RHEL 5.4 64 / 10.2B03
    /Pinne
  8. TomBascom
    There is no such functionality currently available. It is on the wish list. Perhaps when I get back from my 6 month South Pacific vacation ;)
  9. pinne65
    pinne65 Member
    Well, that xplains it. Have a great vacation and watch out for the south pole!
  10. TomBascom
    We'll need to get the Kickstarter campaign in high gear first - that's the *needed* 6 month South Pacific vacation - not the /planned/ one :(
  11. kctechllc
    Can you change the format of Connections on the main dashboard to >,>>9? This is in the web client.
  12. casorohi
    casorohi Member
    Can multiple database can be monitored through one console or any drop down where to choose the another Databases !
  13. Cringer
    Cringer ProgressTalk.com Moderator Staff Member
    It's designed to be used on one database at a time. Nothing stopping you having multiple shortcuts to different databases though...
  14. TomBascom
    ProTop 3.1 is in the wild ;)
    Various bug fixes.
    Area# added to Table & Index Activity.
    Index Root Block added to Index Activity.
    Space Allocation ("RM Chain") info added to Dashboard.
    Modify Sort Column screen ("z" command).
    LarryD likes this.
  15. Rob Fitzpatrick
  16. TomBascom
    And of course a bug has turned up... 3.1a is now available.
  17. LarryD
    LarryD Member
    Talk about a master at work... patches in a matter of hours! Impressive. ;)
  18. TomBascom
    Better make that 3.1b :(
    That "pick your own sort column" feature might not have been the best idea I ever had...
    I think it is fairly stable now :)
  19. Cringer
    Loving the ease of setup in the latest incarnation, and who doesn't love a pretty graph?
    joey.jeremiah likes this.
Share This Page
