[progress Communities] [progress Openedge Abl] Forum Post: Read-json() Fails To Auto...
Andrey Kobernik
I'm using 10.2B08. Upgrade to v.11 is not an option. My problem is that dataset's READ-JSON() leaves grandparent's key blank. The issue occurs only when data-relations have attributes NESTED and FOREIGN-KEY-HIDDEN. I wouldn't like to drop them out because in my real dataset the foreign keys occupy a lot of space, and my intention is to pass the data on the appserver with async call. Here is example: /* TT and Dataset definition */ DEFINE TEMP-TABLE TParent FIELD ParentKey AS CHAR index xpk IS PRIMARY UNIQUE ParentKey. DEFINE TEMP-TABLE TChild FIELD ParentKey AS CHAR FIELD ChildKey AS CHAR index xpk IS PRIMARY UNIQUE ParentKey ChildKey. DEFINE TEMP-TABLE TGChild FIELD ParentKey AS CHAR FIELD ChildKey AS CHAR FIELD GChildKey AS CHAR index xpk IS PRIMARY UNIQUE ParentKey ChildKey GChildKey. DEFINE DATASET ds1 FOR TParent, TChild, TGChild DATA-RELATION PARENT_Child FOR TParent, TChild NESTED FOREIGN-KEY-HIDDEN RELATION-FIELDS (ParentKey, ParentKey) DATA-RELATION Child_GChild FOR TChild, TGChild NESTED FOREIGN-KEY-HIDDEN RELATION-FIELDS (ParentKey, ParentKey, ChildKey, ChildKey). /* Fill dataset with sample data. There are two parent records. Each of them has two children. Each of the children has two grandchildren. */ CREATE TParent. ASSIGN TParent.ParentKey = "parent1". CREATE TChild. ASSIGN TChild.ParentKey = "parent1" TChild.ChildKey = "child11". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent1" TGChild.ChildKey = "child11" TGChild.GChildKey = "Gchild111". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent1" TGChild.ChildKey = "child11" TGChild.GChildKey = "Gchild112". CREATE TChild. ASSIGN TChild.ParentKey = "parent1" TChild.ChildKey = "child12". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent1" TGChild.ChildKey = "child12" TGChild.GChildKey = "Gchild121". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent1" TGChild.ChildKey = "child12" TGChild.GChildKey = "Gchild122". CREATE TParent. ASSIGN TParent.ParentKey = "parent2". CREATE TChild. ASSIGN TChild.ParentKey = "parent2" TChild.ChildKey = "child21". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent2" TGChild.ChildKey = "child21" TGChild.GChildKey = "Gchild211". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent2" TGChild.ChildKey = "child21" TGChild.GChildKey = "Gchild212". CREATE TChild. ASSIGN TChild.ParentKey = "parent2" TChild.ChildKey = "child22". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent2" TGChild.ChildKey = "child22" TGChild.GChildKey = "Gchild221". CREATE TGChild. ASSIGN TGChild.ParentKey = "parent2" TGChild.ChildKey = "child22" TGChild.GChildKey = "Gchild222". /* All 8 records are OK */ FOR EACH TGChild: DISPLAY TGChild. END. /* Put the dataset's content into json file and then re-read it. */ DATASET ds1:WRITE-JSON("file", "./ds1.json", TRUE). DATASET ds1:EMPTY-DATASET(). DATASET ds1:READ-JSON("file", "./ds1.json"). /* Now the ParentKey is empty in all records. */ FOR EACH TGChild: DISPLAY TGChild. END.
