Sivarami Reddy Marella
Hi Anand, Thanks for the update. Here the issues seems to be my Jar file is not picking. I have changed the class path to like below. pluginclasspath=C:\JNDI-Directory\AdminObjectFinder.jar,C:\Progress\OpenEdge\java\progress.jar,C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar classpath=C:\JNDI-Directory\AdminObjectFinder.jar,C:\Progress\OpenEdge\java\progress.jar,C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar jvmargs=-DsonicMQExtensions=false -DjmsProvider=WebSphereMQ After changing my class path also I am getting the same error message. Whatever we are adding before progress.jar these are not picking. Main >(Aug 8, 2017 11:33:47:505) C:\OpenEdge\WRK\sonicMQ1.server.log opened. Main >(Aug 8, 2017 11:33:47:506) : Starts Adapter server logging. Main >(Aug 8, 2017 11:33:47:506) : LoggingLevel set to = 5 Main >(Aug 8, 2017 11:33:47:506) : The system property: sonicMQExtensions is set to false Main >(Aug 8, 2017 11:33:47:506) : The classpath is set to C:\Progress\OpenEdge\java\progress.jar;C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar;C:\JNDI-Directory\AdminObjectFinder.jar Main >(Aug 8, 2017 11:33:47:541) : Reading jmsProvider.properties from location : C:\Progress\OpenEdge\properties\jmsProvider.properties Main >: A public jmsfromABL.AdminObjectFinder class was not found. Main >====================================================================== Main >(Aug 8, 2017 11:44:08:250) C:\OpenEdge\WRK\sonicMQ1.server.log opened. Main >(Aug 8, 2017 11:44:08:250) : Starts Adapter server logging. Main >(Aug 8, 2017 11:44:08:250) : LoggingLevel set to = 5 Main >(Aug 8, 2017 11:44:08:250) : The system property: sonicMQExtensions is set to false Main >(Aug 8, 2017 11:44:08:251) : The classpath is set to C:\Progress\OpenEdge\java\progress.jar;C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar Main >(Aug 8, 2017 11:44:08:332) : Reading jmsProvider.properties from location : C:\Progress\OpenEdge\properties\jmsProvider.properties Main >: A public jmsfromABL.AdminObjectFinder class was not found. I have one doubt - In the SonicMQ1 service we have added "adapter.progress.jms" name to AppService Name List, where can i find this file or service? What is the hierarchy to pick the jmsfromABL.AdminObjectFinder.jar file? Thanks, Sivarami
