Sivarami Reddy Marella
Hi Anand, Sorry for the late confirmation. I have added the client IP address in channel creation and I have regenerated the .bindings and .jar file by using the latest .tab file.After generating these files I have restarted the progress admin server and SonicMQ adapter also. while restarting the MQ adapter I have received the below errors in server log. Main >====================================================================== Main >(Jul 26, 2017 13:14:39:392) C:\OpenEdge\WRK\sonicMQ1.server.log opened. Main >(Jul 26, 2017 13:14:39:393) : Starts Adapter server logging. Main >(Jul 26, 2017 13:14:39:393) : LoggingLevel set to = 5 Main >(Jul 26, 2017 13:14:39:393) : The system property: sonicMQExtensions is set to false Main >(Jul 26, 2017 13:14:39:393) : The classpath is set to C:\Progress\OpenEdge\java\progress.jar;C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar;C:\websphereMQJMS\websphereMQ\AdminObjectFinder.jar Main >(Jul 26, 2017 13:14:39:756) : Reading jmsProvider.properties from location : C:\Progress\OpenEdge\properties\jmsProvider.properties Main >: A public jmsfromABL.AdminObjectFinder class was not found. Thanks, Sivarami
