Ranjana sinha
Hi Iram, Are you able to see MobileCard keyword as well withing the MobileCards tag? If not , then obfuscation is the issue and we need to replace the obfuscated keyword with MobileCard. Also after upgrade if you generate the XML and export it will work fine. Could you please try that? Regards, Ranjana Sinha
