StoneKeeper
hi,
can anybody help me with that problem:
i wrote some programmcode for the creation of an stream text file. the code works fine and creates the textfile in a correct way on the correct directory.
But if i try to change anything in the connected database during the runtime - nothing happens anymore - no textfile is created.
e.g.
if i try an assign invoicestatus = iNewinvoiceStatus.
something goes wrong with the hole thing. if i remark that out, the programm works correct.
If i try to debug the code, it works until a correct codeposition, then it seems, that the debuger does not know, where it is.
i use progress 8.3a.
thanks in advance for your help
e.g.
