1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Pro Tip: How to get effective help.
Discussion in 'Chit Chat' started by TomBascom, Sep 29, 2014.
  1. TomBascom
    TomBascom Curmudgeon
    This is not in response to any particular post -- there have been a whole bunch lately that are prompting this.
    When you ask a question in a forum and someone takes the time to respond they may ask you some follow-up questions or seek clarification of your issue.
    We do this because we need more information in order to help you.
    The issue may seem very obvious to you -- but we are not you. We do not have access to your systems and we do not have the context that you have about your problem. We often see many, many possible ways to look at a situation and we know, often from painful experience, that jumping to conclusions and making wild guesses is not going to help you. It may even put you in a much worse place than you are.
    Ignoring the follow-up questions or randomly answering small pieces of the question or only those parts that you feel like answering or moving on to some unconnected tangent is not an effective way to get help.
    If you really want help please carefully read the responses and completely answer any follow-up questions.
    We're not asking these things to be annoying. We are trying to help you.
  2.
  3. TheMadDBA
    TheMadDBA Active Member
    Spot on... can this be a sticky in all forums please? :)
  4. Rob Fitzpatrick
    Rob Fitzpatrick ProgressTalk.com Sponsor
    Thanks for this Tom. I think there are also some posting guidelines on the site but at the moment I can't find them.
    In general:
    • Provide OS version information for your platform(s).
      Be specific. Say "Windows Server 2008 R2 SP1" instead of "Windows". Say "Red Hat Enterprise Linux 6.3 64-bit", not "Linux". If there are different platforms for different systems or application tiers, describe them separately if it is relevant to your issue.
    • Provide Progress version information for your platform(s).
      As above; be specific. Provide the version number from the $DLC/version file, i.e. down to the SP and hot-fix level if any. Also mention the architecture (32-bit/64-bit). If your question is about a given Progress product, it may be helpful to list the products you have installed (from showcfg). For example, if your issue is that you can't start more than two AppServer agents, it is very relevant to know whether you installed OE AppServer Basic, OE AppServer Enterprise, or OE DevServer.
    • What did you do?
      If your issue is related to code, it can be very helpful to show a bit of your code rather than just describing it in high-level terms. If posting code, please enclose it in CODE tags or use the "Insert | Code" button in the editor toolbar. (If you don't know how to do that, please ask.) This will make your code legible, which will increase the chances that someone will be patient enough to try to figure it out.
      If your issue is not code-related, describe your steps in sufficient detail that obvious follow-up questions are not required. Use more than one sentence.
    • What did you see?
      Don't say "...and then I got an error message." We can't see your screen. If you encountered one or more error messages, copy them in their entirety and paste them into your post.
    • How are you configured?
      If your post is about troubleshooting or performance tuning, it is likely important for us to know information like:
      • how many databases your client connects to and their sizes;
      • the specs of your servers and/or storage;
      • your client startup params;
      • your database broker startup params (from your .pf or DB log);
      • etc.
  5. Chris Kelleher
    Chris Kelleher Administrator Staff Member
    Great advice, I put up an announcement in all of the development forums for logged in users that links to this thread.
    Marco Mendoza and Cringer like this.
  6. Cringer
    Cringer ProgressTalk.com Moderator Staff Member
    Basic posting guidelines in my sig. I know we had a thread about all of this ages ago. Will try and dig it out.
  7. Chris Kelleher
    I found another one that had lots of useful information in it as well, so I added a link to that in the announcement.
  8. Rob Fitzpatrick
    I knew I'd seen it somewhere... :)
  9. TomBascom
  10. TomBascom
Share This Page
