1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Question Odbc And Multi Tenancy
Discussion in 'Development' started by Ray, Apr 21, 2017 at 8:25 AM.
  1. Ray
    Ray New Member
    I am looking at using OpenEdge Multi Tenancy database for a solution that requires connections via a) a SQL Server Linked server, and b) .Net ODBC connection.
    I am using Progress OpenEdge 11.6 Driver (actually 11.6.3).
    Using OpenEdge Explorer with Sports2000 database, I have:
    • Enabled Multi Tenancy;
    • Created two new Tenants (Ten1 and Ten2);
    • Created two domains (Tenant1 and Tenant2);
    • Created two users Ray@Tenant1 and Ray@Tenant2;
    • Started Brokers (32 bit and 64 bit);
    • On Window (win 7) Created System ODBC sources (one for each Tenancy) Connections Tested OK with Ray@Tenant1/2
    BUT
    On SQL Server I can create a Linked server using ODBC DSNs, I have to supply userid and password on security tab. That works fine. I can see the Caltalogs contains SPORTS2000, Tables contains PUB.Customer etc
    But when a select of this is tried like select CustNum from [SPORTSTEN2].[SPORTS2000].[PUB].[Customer]
    I get this error.
    OLE DB provider "MSDASQL" for linked server "SPORTSTEN2" returned message "[DataDirect][ODBC Progress OpenEdge Wire Protocol driver][OPENEDGE]Access denied (Authorisation failed) (7512)".
    Via a C# program, taken from Progress sample, I can make and open an ODBC connection to this database, but when I execute a select on PUB.Customer I get
    ERROR [HY000] [DataDirect][ODBC Progress OpenEdge Wire Protocol driver][OPENEDGE]Access denied (Authorisation failed) (7512)
    I have looked at user permissions for users using OE explorer. It shows my Tenant Users have can-Read and can-Write on PUB.customer.
    any ideas on what I am missing?
    As you may have guessed I am an MS stack developer. We have used Linked servers and ODBC before for NO Multi Tenancy OpenEdge databases OK.
    PS. SQL Server 2012. DotNet 4.5.2
  2.
  3. Cringer
    Cringer ProgressTalk.com Moderator Staff Member
    Hi Ray thanks for posting. You might get an answer here, but if I were you I'd also post on Progress Community as there's folks on there with a lot of good knowledge who don't read on here.
Share This Page
