davidvilla
Hi, I am trying to dynamically convert a logical value to string with a specific format. It works fine, but the TRUE value is not getting displayed properly. See example below.
In this code, the value for yes is displayed as "A" (instead of "ACTIVE"). This is my problem. I tried replacing "ACTIVE" in the format with some other text and got weird results.
Why does this happen? How do I fix this?
I am using OE11.5 with HP-UX environment.
define variable httOutData as handle no-undo.
define variable bhttOutData as handle no-undo.
create temp-table httOutData.
httOutData:add-new-field("mylogfield","character",0,"ACTIVE/INACTIVE",?,"","ACTIVE-FLAG").
httOutData:temp-table-prepare("httOutData").
bhttOutData = httOutData:default-buffer-handle.
for each tablename no-lock:
bhttOutData:buffer-create().
bhttOutData:buffer-field(1):buffer-value = string(tablename.logfield,bhttOutData:buffer-field(1):format).
disp bhttOutData:buffer-field(1):buffer-value tablename.logfield .
end.
