• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
Answered Help PDFInclude
#1
Good Morning.
I need a help, with the PDFInclude library
I need to generate a PDF document, based on another PDF template document.
When copying the file into the new generated, I must change a word within the template.
Eg, inside the pdf file, read the string "& OP" and when generating a new swap file
the string by the number of the Production Order.
If someone has a very simple model, and I'm very grateful.
I'm trying to use the procedure: pdf_ReplaceTxt, but to no avail.
Thank you
