I using progress V9. I have created a script to dump/load db. it was working fine few month ago until today.
I have able to use dump/load script. but when i try to dump again using command after i load db "/usr/dlc/bin/pro exc2 -1 -rx -p dict.p" I got db error "598". I have seach for this error. it to do with "<file-name> is a copy of <file-name>. Database cannot be opened.(598) PROGRESS tried to open a multi-volume database, identified by the first pathname. This structure file, however, is a copy of the structure file identified by the second pathname". I recreate structure file this time I try it with manually load it works fine. then I retried using my script got it same error.
I compare exc2.db file using script and manually one the byt size are the same. But more the both file side by side its different. The exc2.db using script one seem missing the head and more infomation. I not sure why this happen. Can some please explain to me why it happen.
Thanks,
Thanks,
