dlangschied
I am having a great deal of difficulty with OE! Our upgrade to OE included the need to create SQL users for ODBC connectivity. The initial impact of this was that promon did not show the users name, so disconnecting a user session on the OS (linux) required more work. Then, all of sudden, on the linux side, the user connection showed up and no longer appeared when logging into PE. It does not impact the ODBC connection (thank God). When ever we bring down the database (every week in test), the ODBC connection stops working and once we restart the server it returns.
My latest issue is with batch jobs on the server. We have an app (using different db then above) that has batch agents that connect to the database and process maintenance tasks at scheduled times. These agent connections sometimes hang. We try to discourage root login to disconnect users in promon (could inadvertantly shutdown db, BAD). So, we login as the batch user to disconnect. Only, the user name is not there and won't allow for a disconnect. Tried to create the user in the database with negative results. In fact, I get a "no resources error". I am at a loss!
I need to:
1. Figure out why my user names suddenly appeared in my ERP database, with the ODBC agents intact (and how to return to the previous disposition).
2. Figure out why a restart of the database causes the ODBC connections to fail, but return on restart (second time).
3. Figure out how to get the user name to appear in promon with a local connection (this would also eliminate 1, if it is possible to do it without creating a database user).
I know this is a long post, but I am finding the OE ODBC connection for SQL to be a mighty troublesome development.
Thanks!
I need to:
Thanks!
